Introduzione
This USB cable allows the printer to be connected to your computer.
Locate data USB cable.
  • Locate data USB cable.
Aggiungi Commento
Locate the end of the cable that plugs into the printer.
  • Locate the end of the cable that plugs into the printer.
Aggiungi Commento
Insert this cable end to the port in the leftmost edge behind the printer where there is a rectangular indent. Insert this cable end to the port in the leftmost edge behind the printer where there is a rectangular indent.
  • Insert this cable end to the port in the leftmost edge behind the printer where there is a rectangular indent.
Aggiungi Commento
Locate the USB end of the cable. Insert that end into your computer.
  • Locate the USB end of the cable. Insert that end into your computer.
Aggiungi Commento
Conclusione
Once the USB cable is installed, you should be able to print documents from your computer.
Altre 2 persone hanno completato questa guida.
Raymond
Membro da: 15/01/2013
42 Reputazione
7 Guide realizzate
Cal Poly, Team 18-38, Regan Winter 2013 Membro di Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 426
