Introduzione
The adapter connects the power chord to the printer.
Locate adapter and observe that the two contacts, marked by the red rectangle, of the adapter are facing up.
  • Locate adapter and observe that the two contacts, marked by the red rectangle, of the adapter are facing up.
Aggiungi Commento
Insert adapter into the bottom-right slot behind the printer with the adapter end facing outward.
  • Insert adapter into the bottom-right slot behind the printer with the adapter end facing outward.
Aggiungi Commento
Firmly push adapter in until you hear a click.
  • Firmly push adapter in until you hear a click.
Aggiungi Commento
Conclusione
The adapter should be securely inserted into the back end of the printer and be ready for use.
Raymond
Membro da: 15/01/2013
42 Reputazione
7 Guide realizzate
Cal Poly, Team 18-38, Regan Winter 2013 Membro di Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 682
