Salta al contenuto principale
Lenovo Yoga 720-15IKB Battery Replacement
Cosa ti serve
  1. Lenovo Yoga 720-15IKB Battery Replacement, Bottom Cover: passo 1, immagine 1 di 3 Lenovo Yoga 720-15IKB Battery Replacement, Bottom Cover: passo 1, immagine 2 di 3 Lenovo Yoga 720-15IKB Battery Replacement, Bottom Cover: passo 1, immagine 3 di 3
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Battery Replacement: passo 2, immagine 1 di 2 Lenovo Yoga 720-15IKB Battery Replacement: passo 2, immagine 2 di 2
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Battery Replacement, Battery: passo 3, immagine 1 di 2 Lenovo Yoga 720-15IKB Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Remove the four 4mm screws surrounding the battery with a Phillips #0 screwdriver.
    • Each is marked by "M2x5" with a small white arrow pointing to the screw itself.
  4. Lenovo Yoga 720-15IKB Battery Replacement: passo 4, immagine 1 di 2 Lenovo Yoga 720-15IKB Battery Replacement: passo 4, immagine 2 di 2
    • Pull firmly on the battery connector to disconnect it.
  5. Lenovo Yoga 720-15IKB Battery Replacement: passo 5, immagine 1 di 1
    • Lift the battery out of the case to remove it.
Conclusione
Altre 10 persone hanno completato questa guida.
Cal Poly, Team S19-G3, White Winter 2020 Membro di Cal Poly, Team S19-G3, White Winter 2020
CPSU-WHITE-W20S19G3
4 Membri
25 Guide realizzate
3 Commenti
Excellent guide. Made the job a snap. Especially identifying the screwdriver bit requird.
James Smith - Replica
Good guide. Fairly easy project. Getting the battery connector back in on the replacement battery was by far the hardest part. Be patient with it. It took me a few tries, but it slid in fairly easily once it was all lined up correctly.
Mark Haakenson - Replica
Thank you for the great informative guide! ordering my battery and tools now!
justmelendez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 69
Ultimi 30 Giorni: 296
Tutti i Tempi: 11,278
