Salta al contenuto principale
Lenovo Yoga 710-15IKB Fan Replacement
Cosa ti serve
  1. Lenovo Yoga 710-15IKB Fan  Replacement, Battery: passo 1, immagine 1 di 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the ten 3.3 mm T5 screws from the base cover.
    • The screws aren't all the same length. Be sure to keep the screws sorted as you work.
  2. Lenovo Yoga 710-15IKB Fan  Replacement: passo 2, immagine 1 di 1
    • Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
  3. Lenovo Yoga 710-15IKB Fan  Replacement: passo 3, immagine 1 di 1
    • Lift and remove the back cover.
  4. Lenovo Yoga 710-15IKB Fan  Replacement: passo 4, immagine 1 di 1
    • Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
  5. Lenovo Yoga 710-15IKB Fan  Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
  6. Lenovo Yoga 710-15IKB Fan  Replacement: passo 6, immagine 1 di 1
    • Gently lift and remove the battery.
  7. Lenovo Yoga 710-15IKB Fan  Replacement, Fan: passo 7, immagine 1 di 1
    Compra
    • Use tweezers to grab the fan harness.
    • Gently pull the harness to disconnect from motherboard.
  8. Lenovo Yoga 710-15IKB Fan  Replacement: passo 8, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the four screws holding down the fans.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 24
Tutti i Tempi: 2,150
