Salta al contenuto principale
Lenovo Yoga 710-14ISK Battery Replacement
Cosa ti serve
  1. Lenovo Yoga 710-14ISK Battery Replacement, Remove the base cover screws: passo 1, immagine 1 di 1
    • Remove the M2 × 7 mm, Torx-head screws.
    • Remove the M2 × 5 mm, Torx-head screws.
  2. Lenovo Yoga 710-14ISK Battery Replacement, Remove the base cover: passo 2, immagine 1 di 2 Lenovo Yoga 710-14ISK Battery Replacement, Remove the base cover: passo 2, immagine 2 di 2
    • Insert a prying tool (opening pick) between the base cover and the cover and slide it in the direction shown by arrows to separate the base cover from the cover.
    • Remove the base cover.
  3. Lenovo Yoga 710-14ISK Battery Replacement, Remove the battery: passo 3, immagine 1 di 1
    • Unplug the battery connector.
    • Remove the M2 × 3 mm, Phillips-head screws.
    • Remove the battery pack.
Conclusione
To replace the battery & reassemble your device, follow these instructions in reverse order.
Max Kletskov
Membro da: 04/22/20
40.298 Reputazione
16 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
17.198 Guide realizzate
Un commento
Hi, do i can replace my laptop battery by myself? or i should go to geek squad in best buy.
Jesse Milani - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 15
Tutti i Tempi: 632
