Salta al contenuto principale
Lenovo Yoga 710-14IKB Headphone Jack Replacement
Cosa ti serve
  1. Lenovo Yoga 710-14IKB Headphone Jack Replacement, Back Cover: passo 1, immagine 1 di 1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Headphone Jack Replacement: passo 2, immagine 1 di 3 Lenovo Yoga 710-14IKB Headphone Jack Replacement: passo 2, immagine 2 di 3 Lenovo Yoga 710-14IKB Headphone Jack Replacement: passo 2, immagine 3 di 3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB Headphone Jack Replacement, Battery: passo 3, immagine 1 di 2 Lenovo Yoga 710-14IKB Headphone Jack Replacement, Battery: passo 3, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
    • Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
  4. Lenovo Yoga 710-14IKB Headphone Jack Replacement: passo 4, immagine 1 di 2 Lenovo Yoga 710-14IKB Headphone Jack Replacement: passo 4, immagine 2 di 2
    • Use your fingers or an opening tool to slide the battery connector out of its motherboard socket.
  5. Lenovo Yoga 710-14IKB Headphone Jack Replacement: passo 5, immagine 1 di 1
    • Remove the battery.
  6. Lenovo Yoga 710-14IKB Headphone Jack Replacement, Headphone Jack: passo 6, immagine 1 di 1
    • Remove the two 3mm screws from the headphone jack using a PH00 screwdriver.
    • Make sure not to strip the screws as they can sometimes be hard to remove.
  7. Lenovo Yoga 710-14IKB Headphone Jack Replacement: passo 7, immagine 1 di 1
    • Pop the black bar on the tip of the wire connected to the headphone jack circuitboard.
    • Disconnect the wire.
    • Be careful not to pull or yank the cable.
  8. Lenovo Yoga 710-14IKB Headphone Jack Replacement: passo 8, immagine 1 di 2 Lenovo Yoga 710-14IKB Headphone Jack Replacement: passo 8, immagine 2 di 2
    • Remove the headphone jack circuitboard.
Conclusione
Evan Cruzen
Membro da: 11/01/18
253 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 15
Tutti i Tempi: 595
