Salta al contenuto principale
Lenovo YOGA 730-15IWL Battery Replacement
Cosa ti serve
  1. Lenovo YOGA 730-15IWL Battery Replacement, Remove the base cover screws: passo 1, immagine 1 di 1
    • Remove the screws (M2.0 x 7.0 mm, Torx).
  2. Lenovo YOGA 730-15IWL Battery Replacement, Remove the base cover: passo 2, immagine 1 di 1
    • Remove the base cover. Consider using a spudger.
  3. Lenovo YOGA 730-15IWL Battery Replacement, Remove the battery: passo 3, immagine 1 di 1
    • Unplug the battery connector in the direction shown by arrow
    • Remove the screws (M2.0 x 4.5 mm).
    • Remove the battery pack.
Conclusione
To replace the battery & reassemble your device, follow these instructions in reverse order.
Altre 2 persone hanno completato questa guida.
Max Kletskov
Membro da: 04/22/20
40.298 Reputazione
16 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
17.199 Guide realizzate
2 Commenti
My issue with my Lenovo Yoga 730-15 laptop was not the battery I just successfully replaced. It still does not turn on. The Power button light up for a short time when pressed to power up the laptop. However, it then goes out and the laptop does not startup. Any Ideas?? Thanks
Al Cross - Replica
Check thermal paste. May be getting hot and shutting back off.
William Mobley - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 50
Tutti i Tempi: 1,368
