Salta al contenuto principale
Lenovo YOGA 730-15IKB Wireless Card Replacement
Cosa ti serve
  1. Lenovo YOGA 730-15IKB Wireless Card Replacement, Bottom Cover: passo 1, immagine 1 di 2 Lenovo YOGA 730-15IKB Wireless Card Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Wireless Card Replacement: passo 2, immagine 1 di 2 Lenovo YOGA 730-15IKB Wireless Card Replacement: passo 2, immagine 2 di 2
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Wireless Card Replacement: passo 3, immagine 1 di 1
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Wireless Card Replacement, Wireless Card: passo 4, immagine 1 di 1
    • Remove the sticky tape from the top edge of the wireless card.
  5. Lenovo YOGA 730-15IKB Wireless Card Replacement: passo 5, immagine 1 di 3 Lenovo YOGA 730-15IKB Wireless Card Replacement: passo 5, immagine 2 di 3 Lenovo YOGA 730-15IKB Wireless Card Replacement: passo 5, immagine 3 di 3
    • Pull the black and white antenna wires off of the wireless card.
    • For reassembly, the white wire connects to the right terminal marked "1." The black wire connects to the left terminal marked "2."
  6. Lenovo YOGA 730-15IKB Wireless Card Replacement: passo 6, immagine 1 di 2 Lenovo YOGA 730-15IKB Wireless Card Replacement: passo 6, immagine 2 di 2
    • Remove one 2mm Phillips #1 screw.
  7. Lenovo YOGA 730-15IKB Wireless Card Replacement: passo 7, immagine 1 di 2 Lenovo YOGA 730-15IKB Wireless Card Replacement: passo 7, immagine 2 di 2
    • Pull the wireless card out of the socket at its resting angle.
    • Do not pull straight upward. Pull towards the hinges at the back of the laptop.
Conclusione
Ellis Ruckman
Membro da: 01/23/20
2.545 Reputazione
6 Guide realizzate
Cal Poly, Team S1-G6, White Winter 2020 Membro di Cal Poly, Team S1-G6, White Winter 2020
CPSU-WHITE-W20S1G6
3 Membri
27 Guide realizzate
Un commento
I was able to use an intel AX210NGW WiFi 6 & BT 5.3 to work perfectly - plug and play. It worked at startup. I get download speeds nearly 1,000 Mb/s on a WiFi 6 network. Well worth the upgrade.
George - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 49
Tutti i Tempi: 3,376
