Salta al contenuto principale
Lenovo Touch Y70-70 Hard Drive Replacement
Cosa ti serve
  1. Lenovo Touch Y70-70 Hard Drive Replacement, Back Cover: passo 1, immagine 1 di 1
    • Flip the device so the back is facing you.
    • Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
  2. Lenovo Touch Y70-70 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Use the blue Opening Tool to pry-open the back cover.
    • Slide it around the perimeter of the PC freeing the back cover.
    • Remove the back cover from the device.
  3. Lenovo Touch Y70-70 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 1
    • Use the Phillips #0 screwdriver to unscrew the four screws.
  4. Lenovo Touch Y70-70 Hard Drive Replacement: passo 4, immagine 1 di 1
    • Disconnect the hard drive from the motherboard.
  5. Lenovo Touch Y70-70 Hard Drive Replacement: passo 5, immagine 1 di 1
    • Use the Phillips #0 screwdriver to unscrew the four screws on the sides of the hard drive frame.
    • Remove the hard drive from the frame.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 2,546
