Salta al contenuto principale
Lenovo Thinkpad T450s Keyboard Replacement
Cosa ti serve
  1. Lenovo Thinkpad T450s Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Remove the battery by pulling on the two sliding buttons next to the battery.
  2. Lenovo Thinkpad T450s Keyboard Replacement: passo 2, immagine 1 di 2 Lenovo Thinkpad T450s Keyboard Replacement: passo 2, immagine 2 di 2
    • Remove the seven 5mm screws on the back cover using the Phillips #0 screwdriver.
  3. Lenovo Thinkpad T450s Keyboard Replacement: passo 3, immagine 1 di 1
    • Remove the two rubber stoppers from where the battery previously was.
  4. Lenovo Thinkpad T450s Keyboard Replacement: passo 4, immagine 1 di 2 Lenovo Thinkpad T450s Keyboard Replacement: passo 4, immagine 2 di 2
    • Flip the laptop, shift the keyboard upwards by applying force to the two indents on the keyboard.
    • Remove the six 5mm screws that are on the keyboard using the Phillips #0 screwdriver.
    • These screws are located above the left ctrl key, S, F, J, semicolon, and up arrow keys.
  5. Lenovo Thinkpad T450s Keyboard Replacement: passo 5, immagine 1 di 1
    • Lift the keyboard and flip over exposing the connection to the motherboard.
  6. Lenovo Thinkpad T450s Keyboard Replacement: passo 6, immagine 1 di 1
    • Remove the plastic covering and detach touch point and keyboard cable.
Conclusione
Altre 3 persone hanno completato questa guida.
Nathan Morgan
Membro da: 11/11/19
469 Reputazione
2 Guide realizzate
IUPUI, Team S2-G5, Stella Fall 2019 Membro di IUPUI, Team S2-G5, Stella Fall 2019
IUPUI-STELLA-F19S2G5
3 Membri
2 Guide realizzate
Un commento
If after replacement your keyboard has some keys clacking, make sure you slid the keyboard all the way back. Even a small amount can make some keys feel weird.
Ivan Veloz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 110
Tutti i Tempi: 5,873
