Parti
Nessuna parte richiesta.
Flip the laptop over.
  • Flip the laptop over.
  • Place it on a flat, sturdy surface.
  • Remove the battery by moving the battery latch and slowly sliding the battery out.
  • Locate the drive enclosure.
Aggiungi Commento
Use a small Phillips screwdriver to unscrew the single screw that holds down the drive enclosure cover.
  • Use a small Phillips screwdriver to unscrew the single screw that holds down the drive enclosure cover.
  • The screw is designed to remain within the plastic cover. (This is called a captive screw.) Don't worry about extracting it completely.
Aggiungi Commento
Carefully remove the drive enclosure cover.
  • Carefully remove the drive enclosure cover.
  • Do not break the small latches on the sides of the cover.
Aggiungi Commento
Insert a spudger (or a similar tool) under the loop of the black pull tab, and gently pull it out from above the hard drive.
  • Insert a spudger (or a similar tool) under the loop of the black pull tab, and gently pull it out from above the hard drive.
Aggiungi Commento
Continue pulling on the pull tab until the hard drive and the two plastic rails come out of the enclosure.
  • Continue pulling on the pull tab until the hard drive and the two plastic rails come out of the enclosure.
  • Pull on the tab firmly but slowly. The hard drive should come out of the enclosure effortlessly.
Aggiungi Commento
Remove the plastic rails from the old drive and place them on the new drive.
  • Remove the plastic rails from the old drive and place them on the new drive.
Aggiungi Commento
Conclusione
Altre 21 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 121
Ultimi 30 Giorni: 465
Tutti i Tempi: 40,813
