Introduzione
How to replace the keyboard in a Lenovo ThinkPad Yoga 2013. This guide will help you to successfully replace your keyboard.
Cosa ti serve
Flip the laptop over so the bottom is facing you.
Remove the ten screws using a Phillips #1 screwdriver.
Using the plastic opening tool, pry the bottom cover off the laptop.
Remove the two screws from the retainer for the ports using a Phillips #1 screwdriver.
Remove the nine screws from the motherboard using a Phillips #1 screwdriver.
Remove the four screws from the fan under the motherboard using a Phillips #1 screwdriver.
Remove the fan from the motherboard.
Altre 2 persone hanno completato questa guida.
