Salta al contenuto principale
Lenovo ThinkPad Yoga 260 Wifi-Card Replacement
Cosa ti serve
  1. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Back Cover: passo 1, immagine 1 di 1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: passo 3, immagine 2 di 2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: passo 4, immagine 1 di 2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: passo 4, immagine 2 di 2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Wifi-Card: passo 5, immagine 1 di 3 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Wifi-Card: passo 5, immagine 2 di 3 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement, Wifi-Card: passo 5, immagine 3 di 3
    • Using a Phillips #1 screwdriver, remove the 1.3 mm screw and set it aside.
  6. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: passo 6, immagine 1 di 2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: passo 6, immagine 2 di 2
    • Carefully pull out the Wi-Fi card.
    • Be sure to pull laterally, not upwards.
  7. Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: passo 7, immagine 1 di 2 Lenovo ThinkPad Yoga 260 Wifi-Card Replacement: passo 7, immagine 2 di 2
    • Carefully disconnect the 2 cables from the WiFi-Card as indicated on the card label.
    • Set the Wifi-Card aside.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 854
