Salta al contenuto principale
Lenovo ThinkPad X390 Yoga Battery Replacement
Cosa ti serve
  1. Lenovo ThinkPad X390 Yoga Battery Replacement, Back Case: passo 1, immagine 1 di 1
    • Use a Phillips #1 screwdriver to unscrew the eight captive screws from the back of the device.
    • The screws should not be removed from the back panel, so don't try to force them out.
  2. Lenovo ThinkPad X390 Yoga Battery Replacement: passo 2, immagine 1 di 1
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
  3. Lenovo ThinkPad X390 Yoga Battery Replacement: passo 3, immagine 1 di 1
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga Battery Replacement, Battery: passo 4, immagine 1 di 1
    • Use the spudger to disconnect the battery from the motherboard at the connector socket.
  5. Lenovo ThinkPad X390 Yoga Battery Replacement: passo 5, immagine 1 di 1
    • Use the Phillips #1 screwdriver to remove five 4 mm screws around the battery.
  6. Lenovo ThinkPad X390 Yoga Battery Replacement: passo 6, immagine 1 di 1
    • Lift the battery out of the laptop by lifting up.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 133
Tutti i Tempi: 1,553
