Salta al contenuto principale
Lenovo ThinkPad X140e Back Panel Replacement
Cosa ti serve
  1. Lenovo ThinkPad X140e Back Panel Replacement, Back Panel: passo 1, immagine 1 di 1
    • Flip the laptop upside down so that the battery is facing away from you.
    • Battery removal is not necessary to complete this guide.
  2. Lenovo ThinkPad X140e Back Panel Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad X140e Back Panel Replacement: passo 2, immagine 2 di 2
    • Locate the three 3 mm Phillips #0 screws on the back panel.
    • Remove each screw using a small Phillips #0 screwdriver.
  3. Lenovo ThinkPad X140e Back Panel Replacement: passo 3, immagine 1 di 1
    • Using a small plastic opening tool, pry off the back casing starting at a point closest to you and working around the perimeter of the case.
Conclusione
Cal Poly, Team 20-5, Livingston Fall 2016 Membro di Cal Poly, Team 20-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G5
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 448
