Salta al contenuto principale
Lenovo ThinkPad X1 Extreme Speakers Replacement
Cosa ti serve
  1. Lenovo ThinkPad X1 Extreme Speakers Replacement, Back Cover: passo 1, immagine 1 di 3 Lenovo ThinkPad X1 Extreme Speakers Replacement, Back Cover: passo 1, immagine 2 di 3 Lenovo ThinkPad X1 Extreme Speakers Replacement, Back Cover: passo 1, immagine 3 di 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Speakers Replacement, Speakers: passo 2, immagine 1 di 1
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Extreme Speakers Replacement: passo 3, immagine 1 di 1
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
Conclusione
Kristen Gismondi
Membro da: 11/12/14
83.146 Reputazione
204 Guide realizzate
iFixit Membro di iFixit
Staff
137 Membri
17.523 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 14
Tutti i Tempi: 362
