Salta al contenuto principale
Lenovo ThinkPad X1 Extreme Motherboard Replacement
Cosa ti serve
  1. Lenovo ThinkPad X1 Extreme Motherboard Replacement, Battery: passo 1, immagine 1 di 3 Lenovo ThinkPad X1 Extreme Motherboard Replacement, Battery: passo 1, immagine 2 di 3 Lenovo ThinkPad X1 Extreme Motherboard Replacement, Battery: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  2. Lenovo ThinkPad X1 Extreme Motherboard Replacement: passo 2, immagine 1 di 1
    • Lift the battery out of the frame and remove it from the device.
  3. Lenovo ThinkPad X1 Extreme Motherboard Replacement, Fan: passo 3, immagine 1 di 3 Lenovo ThinkPad X1 Extreme Motherboard Replacement, Fan: passo 3, immagine 2 di 3 Lenovo ThinkPad X1 Extreme Motherboard Replacement, Fan: passo 3, immagine 3 di 3
    • Unscrew the 3mm screw holding down the wireless adapter using a Phillips #00 screwdriver.
    • Slide the adapter out of its connector.
    • Detach the black and gray cables and separate them from the frame of the fan by gently pulling upwards.
  4. Lenovo ThinkPad X1 Extreme Motherboard Replacement: passo 4, immagine 1 di 2 Lenovo ThinkPad X1 Extreme Motherboard Replacement: passo 4, immagine 2 di 2
    • Unlatch and remove the cable connecting to the frame of the fan by flipping the thin black tab up.
    • Separate the cable from the frame of the fan.
  5. Lenovo ThinkPad X1 Extreme Motherboard Replacement: passo 5, immagine 1 di 2 Lenovo ThinkPad X1 Extreme Motherboard Replacement: passo 5, immagine 2 di 2
    • Loosen the five screws connecting the fan to the motherboard using a Philips #00 head screwdriver.
    • These screws will not come out and will stay connected to the fan.
  6. Lenovo ThinkPad X1 Extreme Motherboard Replacement: passo 6, immagine 1 di 3 Lenovo ThinkPad X1 Extreme Motherboard Replacement: passo 6, immagine 2 di 3 Lenovo ThinkPad X1 Extreme Motherboard Replacement: passo 6, immagine 3 di 3
    • Gently disconnect the two cables located on right and left side of the fan.
    • To identify these, they are labeled "FANR1" and FANL2" on the motherboard.
    • Lift the fan up and out and remove it from the device.
  7. Lenovo ThinkPad X1 Extreme Motherboard Replacement, Motherboard: passo 7, immagine 1 di 3 Lenovo ThinkPad X1 Extreme Motherboard Replacement, Motherboard: passo 7, immagine 2 di 3 Lenovo ThinkPad X1 Extreme Motherboard Replacement, Motherboard: passo 7, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove the five 4 mm screws below the charging port.
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws.
    • Use a Phillips #00 screwdriver to remove the two 5 mm screws securing a silver plate on the charging port, in the top-right.
    • Remove the silver plate on top of the charging port.
  8. Lenovo ThinkPad X1 Extreme Motherboard Replacement: passo 8, immagine 1 di 3 Lenovo ThinkPad X1 Extreme Motherboard Replacement: passo 8, immagine 2 di 3 Lenovo ThinkPad X1 Extreme Motherboard Replacement: passo 8, immagine 3 di 3
    • Disconnect all the ribbon wires from the motherboard.
    • All ribbon wires can be disconnected by flipping up the thin black tab at their connection points, and pulling the ribbon out.
  9. Lenovo ThinkPad X1 Extreme Motherboard Replacement: passo 9, immagine 1 di 3 Lenovo ThinkPad X1 Extreme Motherboard Replacement: passo 9, immagine 2 di 3 Lenovo ThinkPad X1 Extreme Motherboard Replacement: passo 9, immagine 3 di 3
    • Disconnect the black attachment at the top right corner of the motherboard.
    • Insert the SIM eject bit into the small hole on the top and apply a small amount of pressure to release the clip.
    • While maintaining pressure, gently pull on the wire that is connected to it to remove it.
  10. Lenovo ThinkPad X1 Extreme Motherboard Replacement: passo 10, immagine 1 di 1
    • Gently lift the motherboard out of the computer.
Conclusione
Altre 2 persone hanno completato questa guida.
Brant Baugher
Membro da: 02/10/20
166 Reputazione
1 Guida realizzata
Cal Poly, Team S7-G3, Regan Winter 2020 Membro di Cal Poly, Team S7-G3, Regan Winter 2020
CPSU-REGAN-W20S7G3
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 53
Tutti i Tempi: 3,374
