Salta al contenuto principale
Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement
Cosa ti serve
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement, Back Cover: passo 1, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement, Battery: passo 3, immagine 1 di 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: passo 4, immagine 1 di 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: passo 5, immagine 1 di 1
    • Remove the battery by pulling it directly towards you.
Conclusione
Altre 9 persone hanno completato questa guida.
Eevee Murdock
Membro da: 01/23/20
1.086 Reputazione
6 Guide realizzate
Cal Poly, Team S18-G4, White Winter 2020 Membro di Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
4 Membri
7 Guide realizzate
4 Commenti
iFixit replacement battery is rejected by X1 Carbon gen2 chassis as not-genuine/unauthorized. Is there some additional step to getting the battery to be recognized/allowed? Something in the BIOS? Or is the battery faulty?
lenovo_battery - Replica
Any comments from @ifixit?
Martin Optilon - Replica
Hi there! Thanks for bringing this to our attention. @lenovo_battery, sorry to hear you're having trouble with your battery. Please reach out directly to our customer support team by emailing support@ifixit.com.
Kristen Gismondi -
Hi,
Great guide. I found that my screw heads were a bit stripped and the #0 driver was too small and bounced too much. The #1 driver worked better for me. Thanks for promoting the repair revolution! - MiLo
milostudios - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 103
Tutti i Tempi: 4,545
