Salta al contenuto principale
Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement
Cosa ti serve
  1. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement, Optical Disk Drive (ODD): passo 1, immagine 1 di 2 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement, Optical Disk Drive (ODD): passo 1, immagine 2 di 2
    • Turn your laptop over so the backplate is facing you.
    • Start with your Phillips #0 screwdriver and unscrew the 2 screws in each of the top corners of the backplate.
    • These screws should stay put on the backplate, and should not fall off.
  2. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: passo 2, immagine 2 di 2
    • With your Phillips #00 screwdriver, simply remove the one 3mm screw on the upper left side.
  3. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: passo 3, immagine 1 di 3 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: passo 3, immagine 2 di 3 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: passo 3, immagine 3 di 3
    • Remove the ODD by using a plastic opening tool to push the drive out of the side of the laptop.
    • Make sure to place the tool where we removed the screw holding the drive in place in Step 2.
  4. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: passo 4, immagine 1 di 1
    • Once the ODD has popped out, simply grab and pull out the drive bay.
Conclusione
Isaac
Membro da: 10/30/23
109 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 75
