Salta al contenuto principale
Lenovo ThinkPad T495 Wi-Fi Card Replacement
Cosa ti serve
  1. Lenovo ThinkPad T495 Wi-Fi Card Replacement, Baseplate: passo 1, immagine 1 di 1
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
  2. Lenovo ThinkPad T495 Wi-Fi Card Replacement: passo 2, immagine 1 di 1
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
  3. Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: passo 3, immagine 1 di 3 Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: passo 3, immagine 2 di 3 Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to lift the two coaxial cable connectors vertically, disconnecting them from the Wi-Fi card.
    • Use a Phillips #00 screwdriver to remove the 6 mm screw, causing the Wi-Fi card to pop up.
  4. Lenovo ThinkPad T495 Wi-Fi Card Replacement: passo 4, immagine 1 di 2 Lenovo ThinkPad T495 Wi-Fi Card Replacement: passo 4, immagine 2 di 2
    • Grip the Wi-Fi card between your fingers and pull it in the direction of the card, at a slight angle, until it releases from its port.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 27
Tutti i Tempi: 779
