Salta al contenuto principale
Lenovo ThinkPad T470S Batteries Replacement
Cosa ti serve
  1. Lenovo ThinkPad T470S Batteries Replacement, Bottom Panel: passo 1, immagine 1 di 1
    • Use a Phillips #000 screwdriver to remove the five 7 mm screws from the bottom of the laptop.
    • Lift the bottom panel up and off the laptop.
  2. Lenovo ThinkPad T470S Batteries Replacement, Batteries: passo 2, immagine 1 di 3 Lenovo ThinkPad T470S Batteries Replacement, Batteries: passo 2, immagine 2 di 3 Lenovo ThinkPad T470S Batteries Replacement, Batteries: passo 2, immagine 3 di 3
    • Remove two screws on the bottom of the upper battery using a Phillips #000 screwdriver.
    • Remove three screws on the top of the lower battery using a Phillips #000 screwdriver.
    • Peel back connecting supporting tape on each of the batteries.
  3. Lenovo ThinkPad T470S Batteries Replacement: passo 3, immagine 1 di 3 Lenovo ThinkPad T470S Batteries Replacement: passo 3, immagine 2 di 3 Lenovo ThinkPad T470S Batteries Replacement: passo 3, immagine 3 di 3
    • Slide the upper battery out of the device, away from the laptop.
    • Slide the lower battery out of the device, away from the laptop.
Conclusione
Altre 7 persone hanno completato questa guida.
Un commento
Is the rear battery, battery 1 or 2? It's my battery 2 that won't charge any more. But maybe I should just change them both. Do you sell both of them or just the one?
Trisha Moore - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 23
Ultimi 7 Giorni: 174
Ultimi 30 Giorni: 836
Tutti i Tempi: 27,024
