Salta al contenuto principale
Lenovo ThinkPad T430s Display Replacement
Cosa ti serve
  1. Lenovo ThinkPad T430s Display Replacement, Battery: passo 1, immagine 1 di 3 Lenovo ThinkPad T430s Display Replacement, Battery: passo 1, immagine 2 di 3 Lenovo ThinkPad T430s Display Replacement, Battery: passo 1, immagine 3 di 3
    • Flip your ThinkPad on its back.
    • In the bottom left corner of your ThinkPad, slide the lever to the left. Hold the lever there.
    • Use your other hand to lift the battery up by prying the notch to the left of the lever.
    • Tilt the battery up and remove it from the ThinkPad.
  2. Lenovo ThinkPad T430s Display Replacement, Display: passo 2, immagine 1 di 3 Lenovo ThinkPad T430s Display Replacement, Display: passo 2, immagine 2 di 3 Lenovo ThinkPad T430s Display Replacement, Display: passo 2, immagine 3 di 3
    • Rotate your ThinkPad so the back side faces you.
    • With the Phillips #1 screwdriver, remove the two 70 mm screws in the right and left corners.
    • Open the ThinkPad so the screen faces up. Lift the screen from its hinges.
  3. Lenovo ThinkPad T430s Display Replacement: passo 3, immagine 1 di 3 Lenovo ThinkPad T430s Display Replacement: passo 3, immagine 2 di 3 Lenovo ThinkPad T430s Display Replacement: passo 3, immagine 3 di 3
    • With the Phillips #0 screwdriver, remove the two 50 mm screws securing the plastic display case.
    • Wedge the flat end of the spudger in between the display case and the screen. Unsnap the top case from the bottom piece holding the screen.
    • Remove the case and set it aside.
  4. Lenovo ThinkPad T430s Display Replacement: passo 4, immagine 1 di 3 Lenovo ThinkPad T430s Display Replacement: passo 4, immagine 2 di 3 Lenovo ThinkPad T430s Display Replacement: passo 4, immagine 3 di 3
    • Unscrew the four 30 mm screws holding the screen to the case.
    • Lift the screen out of the case.
    • Flip the screen over.
  5. Lenovo ThinkPad T430s Display Replacement: passo 5, immagine 1 di 3 Lenovo ThinkPad T430s Display Replacement: passo 5, immagine 2 di 3 Lenovo ThinkPad T430s Display Replacement: passo 5, immagine 3 di 3
    • Peel away the tape holding the cable down with the flat end of the spudger.
    • Pull the cable out of its socket.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 74
Tutti i Tempi: 2,338
