Salta al contenuto principale
Lenovo ThinkPad T400s Keyboard Replacement
Cosa ti serve
  1. Lenovo ThinkPad T400s Keyboard Replacement, Keyboard: passo 1, immagine 1 di 2 Lenovo ThinkPad T400s Keyboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Remove the Phillips #0-6mm screw.
    • Lift up the back cover to the RAM cards.
  2. Lenovo ThinkPad T400s Keyboard Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad T400s Keyboard Replacement: passo 2, immagine 2 di 2
    • Pull the lock for the baterry to the left to unlock.
    • While holding the tab in the unlocked position, remove the battery.
  3. Lenovo ThinkPad T400s Keyboard Replacement: passo 3, immagine 1 di 1
    • Remove the three Phillips #0-6mm screws on the back panel.
    • These screws are marked with a keyboard symbol next to them.
  4. Lenovo ThinkPad T400s Keyboard Replacement: passo 4, immagine 1 di 3 Lenovo ThinkPad T400s Keyboard Replacement: passo 4, immagine 2 di 3 Lenovo ThinkPad T400s Keyboard Replacement: passo 4, immagine 3 di 3
    • Turn the computer over and open the lid.
    • Wedge the small metal spudger between the palm rest and the keyboard.
  5. Lenovo ThinkPad T400s Keyboard Replacement: passo 5, immagine 1 di 3 Lenovo ThinkPad T400s Keyboard Replacement: passo 5, immagine 2 di 3 Lenovo ThinkPad T400s Keyboard Replacement: passo 5, immagine 3 di 3
    • Lift up the keyboard, but be careful not to completely remove.
    • Don't lift the keyboard too quickly, there is a connector cable you must disconnect first.
    • Wedge the small plastic opening tool underneath copper band and tilt back.
    • Remove keyboard to replace.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 6-18, Maness Spring 2015 Membro di Cal Poly, Team 6-18, Maness Spring 2015
CPSU-MANESS-S15S6G18
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,468
