Salta al contenuto principale
Lenovo N21 Chromebook Motherboard and Camera Replacement
Cosa ti serve
  1. Lenovo N21 Chromebook Motherboard and Camera Replacement, Keyboard and Trackpad Panel: passo 1, immagine 1 di 2 Lenovo N21 Chromebook Motherboard and Camera Replacement, Keyboard and Trackpad Panel: passo 1, immagine 2 di 2
    • Power down the Chromebook before starting any repair.
    • Opening up your Chromebook voids the manufacturer warranty.
    • Use a screwdriver to remove the six 5.0mm Phillips screws from the bottom housing of the Chromebook.
  2. Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 2, immagine 1 di 2 Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool to pry off the four rubber pegs from the bottom housing.
  3. Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 3, immagine 1 di 2 Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 3, immagine 2 di 2
    • Use a screwdriver to remove the four 5.0mm Phillips screws located under the rubber soles.
  4. Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 4, immagine 1 di 3 Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 4, immagine 2 di 3 Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 4, immagine 3 di 3
    • Flip the laptop over and open the screen.
    • Gently pry the keyboard and trackpad panel away from the bottom housing using a plastic opening tool.
    • Once completely separated, do not immediately pull the panel completely away from the bottom housing. There are wires that are still connecting the panel to the rest of the internals of the Chromebook.
  5. Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 5, immagine 1 di 2 Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 5, immagine 2 di 2
    • Disconnect the keyboard ribbon cable by lifting the ZIF connector lock with a plastic opening tool or fingernail and gently pulling the ribbon cable straight out of its socket.
  6. Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 6, immagine 1 di 3 Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 6, immagine 2 di 3 Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 6, immagine 3 di 3
    • Disconnect the trackpad ribbon cable by lifting the ZIF connector lock with a small prying tool or fingernail and gently pulling the ribbon cable straight out of its socket.
  7. Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 7, immagine 1 di 1
    • Remove the keyboard and trackpad panel away from the device.
  8. Lenovo N21 Chromebook Motherboard and Camera Replacement, WiFi Card: passo 8, immagine 1 di 2 Lenovo N21 Chromebook Motherboard and Camera Replacement, WiFi Card: passo 8, immagine 2 di 2
    • Use a screwdriver to remove the single 3mm Phillips screw that is holding the WiFi card in place.
  9. Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 9, immagine 1 di 2 Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 9, immagine 2 di 2
    • Remove the black and white wires attached to WiFi card by gently lifting them upwards.
    • When re-attaching the wires, make sure they are in the correct placement. You do not want to switch the black and white wires.
  10. Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 10, immagine 1 di 2 Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 10, immagine 2 di 2
    • Remove the WiFi card by pulling it straight out of its connector.
    • Keep the WiFi card horizontal and pull straight back to avoid causing the part harm.
  11. Lenovo N21 Chromebook Motherboard and Camera Replacement, Screen: passo 11, immagine 1 di 2 Lenovo N21 Chromebook Motherboard and Camera Replacement, Screen: passo 11, immagine 2 di 2
    • Carefully pry off the six small rubber pads around the screen with a plastic opening tool to expose the screws.
    • There are two rubber pads without screws underneath that do not need to be removed.
  12. Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 12, immagine 1 di 2 Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 12, immagine 2 di 2
    • Remove the six 4.0mm Phillips screws that are underneath the rubber pads with a screwdriver.
  13. Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 13, immagine 1 di 2 Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 13, immagine 2 di 2
    • Use a plastic opening tool to carefully pry the thin plastic frame away from the screen.
    • The bottom edge of the frame has adhesive on it, and will take a little more power to peel away. Be careful not to bend the plastic too far or it will snap.
  14. Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 14, immagine 1 di 2 Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 14, immagine 2 di 2
    • Remove the four 3.0mm Phillips screws symmetrically placed on either side of the screen.
  15. Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 15, immagine 1 di 2 Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 15, immagine 2 di 2
    • Pull the cable connecting the motherboard to the screen straight out from the back of the screen.
    • The screen is very fragile. When handling it, avoid applying uneven pressure on or bending the screen.
  16. Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 16, immagine 1 di 1
    • Remove the screen from the device.
  17. Lenovo N21 Chromebook Motherboard and Camera Replacement, Motherboard and Camera: passo 17, immagine 1 di 2 Lenovo N21 Chromebook Motherboard and Camera Replacement, Motherboard and Camera: passo 17, immagine 2 di 2
    • Remove the two 4.0 mm Phillips screws from the right side of the camera.
    • Once the two screws are removed, carefully pull the camera off the top of the screen.
  18. Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 18, immagine 1 di 3 Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 18, immagine 2 di 3 Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 18, immagine 3 di 3
    • Disconnect the battery by pulling the battery cable connector straight out.
  19. Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 19, immagine 1 di 2 Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 19, immagine 2 di 2
    • Disconnect the USB cable from its ZIF connector by lifting up on the ZIF tab and pulling the cable straight out.
  20. Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 20, immagine 1 di 2 Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 20, immagine 2 di 2
    • Disconnect the speakers by pulling the two speaker cables straight out of their connectors.
  21. Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 21, immagine 1 di 2 Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 21, immagine 2 di 2
    • Use a screwdriver to remove the five 3.0mm Phillips screws from the motherboard.
  22. Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 22, immagine 1 di 1
    • Use a screwdriver to loosen the two screws that are attached to the CPU cover in the center of the motherboard.
    • Do not attempt to completely remove the screws from the CPU cover, just unscrew them in their place until the CPU cover can be removed.
  23. Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 23, immagine 1 di 1
    • Lift the CPU cover away from the CPU.
    • Do not touch the CPU itself once its metal cover is removed. The CPU is extremely delicate, and oil from fingers may damage the part.
  24. Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 24, immagine 1 di 1
    • The motherboard is now free from the bottom housing of the Chromebook.
    • The camera is still connected to the motherboard, so the camera needs to also be removed before the two components can be completely removed.
  25. Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 25, immagine 1 di 2 Lenovo N21 Chromebook Motherboard and Camera Replacement: passo 25, immagine 2 di 2
    • Carefully remove the camera with the motherboard by gently pulling on the wires that are adhered to the back of the screen cover.
    • The motherboard and camera can now be removed from the device.
Conclusione
Altre 3 persone hanno completato questa guida.
Lynette Cox
Membro da: 04/26/17
757 Reputazione
2 Guide realizzate
Cal Poly, Team S21-G2, Livingston Spring 2017 Membro di Cal Poly, Team S21-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G2
4 Membri
12 Guide realizzate
Un commento
Can you just remove the webcam and leave it like that?
robert bailey - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 19
Tutti i Tempi: 3,857
