Salta al contenuto principale
Lenovo Legion Y530-15ICH RAM Replacement
Cosa ti serve
  1. Lenovo Legion Y530-15ICH RAM Replacement, Back Cover: passo 1, immagine 1 di 1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7 mm screws
    • Six 4 mm screws
  2. Lenovo Legion Y530-15ICH RAM Replacement: passo 2, immagine 1 di 2 Lenovo Legion Y530-15ICH RAM Replacement: passo 2, immagine 2 di 2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH RAM Replacement, RAM: passo 3, immagine 1 di 2 Lenovo Legion Y530-15ICH RAM Replacement, RAM: passo 3, immagine 2 di 2
    • Use the plastic opening tool to unlatch the metal cover that secures the RAM housing.
    • Ensure that the opening tool is only hooked on the metal housing.
  4. Lenovo Legion Y530-15ICH RAM Replacement: passo 4, immagine 1 di 3 Lenovo Legion Y530-15ICH RAM Replacement: passo 4, immagine 2 di 3 Lenovo Legion Y530-15ICH RAM Replacement: passo 4, immagine 3 di 3
    • Push the metal tabs inwards to release the RAM.
    • After the clips are removed, the RAM will push up at an angle.
    • Remove the RAM from the device.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team S7-G1, Regan Winter 2020 Membro di Cal Poly, Team S7-G1, Regan Winter 2020
CPSU-REGAN-W20S7G1
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 69
Tutti i Tempi: 3,493
