Salta al contenuto principale
Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement
Cosa ti serve
  1. Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: passo 1, immagine 1 di 3 Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: passo 1, immagine 2 di 3 Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: passo 1, immagine 3 di 3
    • Carefully remove the broken key(s). Use the flat end of the spudger to gently pop the key off.
    • When removing the key(s) be very cautious not to remove the white plastic pieces underneath with it.
    • When reinstalling key, no spudger is needed. Just pop it into place with fingers.
  2. Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement: passo 2, immagine 1 di 2 Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using the flat end of the spudger, very carefully lift up the corners of the white plastic piece. Do not disconnect the two.
    • With the help of tweezers (needle nose works best), pull the connected plastic pieces out.
    • If the two plastic pieces come apart refer to the last picture, showing the orientation in which they should be connected.
    • For reinstallation of the plastic piece use tweezers to put it back in place and pop the bottom half in before the top.
Conclusione
3 Commenti
This is only for the key caps, what about the keyboard itself?
Rick Montoya - Replica
I agree the video is mislabeled. You are not replacing the board just keys.
Pat Schutte - Replica
Please create a tutorial for keys with stabilizer like space bar and enter keys.
Affix - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 40
Ultimi 30 Giorni: 182
Tutti i Tempi: 10,191
