Salta al contenuto principale
Lenovo Ideatab S6000 Motherboard Replacement
Cosa ti serve
  1. Lenovo Ideatab S6000 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the speaker screens by working them loose with a plastic opening tool. You may need to first loosen them with tweezers or a craft knife.
    • These screens are held in place by glue that is hard to remove. Please take your time to ensure that that this step is done correctly.
  2. Lenovo Ideatab S6000 Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the screws from both of the spots that were covered.
  3. Lenovo Ideatab S6000 Motherboard Replacement: passo 3, immagine 1 di 1
    • DO NOT USE A METAL TOOL FOR THIS.
    • Go all around the casing, prying the screen away from the backing with the spudger.
    • It will make a popping sound each time one of the lock tabs is disconnected.
    • Take your time as you move all around the device when prying the backing off.
  4. Lenovo Ideatab S6000 Motherboard Replacement: passo 4, immagine 1 di 1
    • Pull off the plastic that is covering the battery cable.
  5. Lenovo Ideatab S6000 Motherboard Replacement: passo 5, immagine 1 di 2 Lenovo Ideatab S6000 Motherboard Replacement: passo 5, immagine 2 di 2
    • Using either the plastic opening tool or your fingers, gently pull on both sides of the plug to release it.
  6. Lenovo Ideatab S6000 Motherboard Replacement: passo 6, immagine 1 di 1
    • Remove the battery by grabbing the tab shown and pulling up.
    • The battery is held to the device by adhesive. Pull the battery up from the tab and it will lift out with a bit of effort.
  7. Lenovo Ideatab S6000 Motherboard Replacement, Speakers: passo 7, immagine 1 di 3 Lenovo Ideatab S6000 Motherboard Replacement, Speakers: passo 7, immagine 2 di 3 Lenovo Ideatab S6000 Motherboard Replacement, Speakers: passo 7, immagine 3 di 3
    • The speakers are connected to the tablet by glue and require a lot of prying to remove.
    • Make sure to get all the way under the speakers when prying.
  8. Lenovo Ideatab S6000 Motherboard Replacement: passo 8, immagine 1 di 2 Lenovo Ideatab S6000 Motherboard Replacement: passo 8, immagine 2 di 2
    • This step is not necessary if you aren't replacing the speakers.
    • To the remove the wires heat the solder connecting the wires to the board, and gently pull on the wires.
    • Remember the placement of the red and black wires.
    • Connect new speakers by soldering the wires onto the board.
  9. Lenovo Ideatab S6000 Motherboard Replacement, Vibration Motor: passo 9, immagine 1 di 1
    • Use the spudger to pry up the vibration motor.
  10. Lenovo Ideatab S6000 Motherboard Replacement, Motherboard: passo 10, immagine 1 di 1
    • Remove the 3.16mm screws highlighted in red
  11. Lenovo Ideatab S6000 Motherboard Replacement: passo 11, immagine 1 di 1
    • Force the ribbon cables out by pulling up the cables through the use of the plastic opening tool.
  12. Lenovo Ideatab S6000 Motherboard Replacement: passo 12, immagine 1 di 1
    • Flip the black tab up to unlock the cables by using the plastic opening tool.
  13. Lenovo Ideatab S6000 Motherboard Replacement: passo 13, immagine 1 di 1
    • Remove the piece of tape by pulling it up through the use of your hand.
  14. Lenovo Ideatab S6000 Motherboard Replacement: passo 14, immagine 1 di 2 Lenovo Ideatab S6000 Motherboard Replacement: passo 14, immagine 2 di 2
    • Remove the tape by pulling it up through the use of the plastic opening tool.
  15. Lenovo Ideatab S6000 Motherboard Replacement: passo 15, immagine 1 di 2 Lenovo Ideatab S6000 Motherboard Replacement: passo 15, immagine 2 di 2
    • Unlike the other small connectors this one does not flip up. You need to pull the connector cable to release this
    • Lift the tab by pulling it up with your hand.
  16. Lenovo Ideatab S6000 Motherboard Replacement: passo 16, immagine 1 di 1
    • Lift up the cables connected to the tab by using the spudger tool.
  17. Lenovo Ideatab S6000 Motherboard Replacement: passo 17, immagine 1 di 1
    • Remove the tablet's Motherboard by lifting it up with your hands.
Conclusione
Altre 8 persone hanno completato questa guida.
USF Tampa, Team 10-4, Brown Fall 2014 Membro di USF Tampa, Team 10-4, Brown Fall 2014
USFT-BROWN-F14S10G4
4 Membri
10 Guide realizzate
3 Commenti
Just followed this on my father's tablet, worked like a charm!
One step missing, there's a connector for the camera between steps 16 and 17 that needs pried up before taking the board off.
Other than that THANK YOU!!! :)
Mikel Farley - Replica
Any schematics or board view for this board out there?
DANIEL HOCH - Replica
Best purchase of mother board?
Terry Williams - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 8,190
