Salta al contenuto principale
Lenovo Ideapad Yoga 2 11 Battery Replacement
Cosa ti serve
  1. Lenovo Ideapad Yoga 2 11 Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • Begin by turning your closed laptop so that you are looking at the bottom panel.
  2. Lenovo Ideapad Yoga 2 11 Battery Replacement: passo 2, immagine 1 di 2 Lenovo Ideapad Yoga 2 11 Battery Replacement: passo 2, immagine 2 di 2
    • Locate the 10 screws (6mm) around the border of the panel.
    • Using the Torx T5 Screwdriver, remove the screws.
  3. Lenovo Ideapad Yoga 2 11 Battery Replacement: passo 3, immagine 1 di 1
    • Now that the screws are removed, gently lift the back panel upwards to detach it from the rest of your laptop.
  4. Lenovo Ideapad Yoga 2 11 Battery Replacement, Battery: passo 4, immagine 1 di 2 Lenovo Ideapad Yoga 2 11 Battery Replacement, Battery: passo 4, immagine 2 di 2
    • Locate the battery in the bottom right corner.
    • Using a Phillips #000, remove the 6 screws (3.5mm) on the border of the battery and the 7th screw (6.5mm) that is in the center of the battery.
  5. Lenovo Ideapad Yoga 2 11 Battery Replacement: passo 5, immagine 1 di 3 Lenovo Ideapad Yoga 2 11 Battery Replacement: passo 5, immagine 2 di 3 Lenovo Ideapad Yoga 2 11 Battery Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Locate the cable connecting to the battery. It is located at the top-center of the battery.
    • Use a pair of tweezers and place it so that the tweezer is around the cables. Gently pull the cables towards the battery to disconnect the cable.
  6. Lenovo Ideapad Yoga 2 11 Battery Replacement: passo 6, immagine 1 di 2 Lenovo Ideapad Yoga 2 11 Battery Replacement: passo 6, immagine 2 di 2
    • There may be tape around the edge of the battery to secure some wires. Use a pair of tweezers to remove the tape so that the wires are no longer attached to the battery.
  7. Lenovo Ideapad Yoga 2 11 Battery Replacement: passo 7, immagine 1 di 2 Lenovo Ideapad Yoga 2 11 Battery Replacement: passo 7, immagine 2 di 2
    • After you have unscrewed the screws, unplugged the cable, and removed the tape and wires, you can remove the battery from your laptop.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
Excellent instructions makes it easy even for novice
bhimanagouda patil - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,815
