Introduzione
If you have any problem with your display screen, follow these steps to remove it and replace it with a new one.
Be sure to power off your device before taking it apart.
  • Be sure to power off your device before taking it apart.
  • Locate the small tab, marked with the lock symbol on the upper right hand of your IdeaTab above the volume control buttons. Use your fingernail to gently open this tab.
  • Use your Phillips #000 screwdriver and remove the 3.5mm screw and put it aside.
    • There may be a sticker covering the head of the screw. If so, remove the sticker with a tweezer and remove the screw.
Aggiungi Commento
Using your blue, plastic opening tool, begin to gently pry the back panel away from the front panel starting at the charging port. Continue prying along the right edge of the back cover.
  • Using your blue, plastic opening tool, begin to gently pry the back panel away from the front panel starting at the charging port. Continue prying along the right edge of the back cover.
    • Pry carefully to avoid cracking or snapping the plastic back cover.
  • Work the plastic opening tool around the entire device, to free the remaining plastic clips and remove back cover.
Aggiungi Commento
Locate the volume key on the right hand side of the tablet.
  • Locate the volume key on the right hand side of the tablet.
  • Slide the volume key upwards to remove it.
Aggiungi Commento
Using a Phillips #000 screwdriver remove the 7 silver M1.4 3.5mm screws from the back plate. Next, with the same screwdriver remove the black M1.4 4.1mm screw.
  • Using a Phillips #000 screwdriver remove the 7 silver M1.4 3.5mm screws from the back plate.
  • Next, with the same screwdriver remove the black M1.4 4.1mm screw.
  • Gently remove the back plate from the device.
Aggiungi Commento
Locate the power key on the top right hand side of the tablet.
  • Locate the power key on the top right hand side of the tablet.
  • Slide the key upwards to remove it.
Aggiungi Commento
Use the plastic opening tool to disconnect the battery wires from the system board. Slide your opening tool under the white plastic piece and gently pull up. Use the plastic opening tool to loosen the battery from the device by lifting up on the battery on all sides. This will detach the battery from the adhesive. Use the plastic opening tool to loosen the battery from the device by lifting up on the battery on all sides. This will detach the battery from the adhesive.
  • Use the plastic opening tool to disconnect the battery wires from the system board. Slide your opening tool under the white plastic piece and gently pull up.
  • Use the plastic opening tool to loosen the battery from the device by lifting up on the battery on all sides. This will detach the battery from the adhesive.
Aggiungi Commento
Locate the volume button mechanism.
  • Locate the volume button mechanism.
  • The volume button mechanism is called an FPC, it is adhered to the device frame. Remove it by prying it off using a tweezer or plastic opening tool.
  • Remove the FPC to the left of the volume button mechanism the same way.
Aggiungi Commento
Locate the power button mechanism.
  • Locate the power button mechanism.
  • Remove the power button mechanism by prying it off using a tweezer or plastic opening tool.
Aggiungi Commento
Remove the circular motor unit by gently pulling up on it using a tweezer.
  • Remove the circular motor unit by gently pulling up on it using a tweezer.
Aggiungi Commento
Locate the component with a QR code printed on it. To disconnect this component you must first detach it from the white connector. To detach it from the connector, use a tweezer to gently rotate the black piece 90 degrees so it is pointing up.
  • Locate the component with a QR code printed on it.
  • To disconnect this component you must first detach it from the white connector.
  • To detach it from the connector, use a tweezer to gently rotate the black piece 90 degrees so it is pointing up.
    • The white connector may have a yellow mylar sticker over it. Peel off the sticker and continue.
  • Once the black piece is pointing up the orange wires can be removed from the connectors. Using a tweezer pull the orange wires horizontally outwards from the white connector.
Aggiungi Commento
Locate the orange cable to the right of the battery tray. To disconnect this component you must first detach it from the white connector. Using a tweezer, pry the black piece upwards and rotate it 90 degrees so it points up.
  • Locate the orange cable to the right of the battery tray.
  • To disconnect this component you must first detach it from the white connector. Using a tweezer, pry the black piece upwards and rotate it 90 degrees so it points up.
    • There may be a yellow mylar sticker onto of the white connector. Peel off the sticker and continue.
  • Once the black piece is pointing up the orange wires can be removed from the connectors. Using a tweezer pull the orange wire horizontally outwards from the white connector.
Aggiungi Commento
Using a #000 Phillips screwdriver, remove the two M1.4 3.5mm screws from the system board and set them aside.
  • Using a #000 Phillips screwdriver, remove the two M1.4 3.5mm screws from the system board and set them aside.
Aggiungi Commento
Locate the audio assembly near the top-right of the device.
  • Locate the audio assembly near the top-right of the device.
  • Remove the audio assembly by inserting the tweezers in the circular hole in the black plastic box and pulling upwards.
Aggiungi Commento
Locate the microphone at the bottom of the device. Remove the microphone from its cavity by using a tweezer to pull up the black a red cords and microphone with them.
  • Locate the microphone at the bottom of the device.
  • Remove the microphone from its cavity by using a tweezer to pull up the black a red cords and microphone with them.
Aggiungi Commento
The system board is now completely free from the device. Carefully lift the system board up off the device and place on a padded surface.
  • The system board is now completely free from the device. Carefully lift the system board up off the device and place on a padded surface.
  • The screen display unit is now ready to be replaced.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Finley Marbury
Membro da: 15/04/2014
403 Reputazione
2 Guide realizzate
Cal Poly, Team 7-21, Regan Spring 2014 Membro di Cal Poly, Team 7-21, Regan Spring 2014
CPSU-REGAN-S14S7G21
4 Membri
6 Guide realizzate
This dose NOT tell you how to replace the screen. Just how to take the board out and battery, Useless.
Lucky Bob - Replica
Bob, it looks like the display assembly should be the last remaining component at the end of the guide—is that not correct? If you are looking to replace an individual display component, such as the digitizer glass, then yes that will require a different approach.
Jeff Suovanen -
I too wonder how the LCD display and digitizer --machine has both come out. Do you pry them out from the front or back. The article stops at the wrong place. How do the screens actually come out.
Arnie Rosen - Replica
It appears that you have to turn over the unit and with a heat gun go around the edges and separate the digitizerscreen from the LCD. I guess they are two separate screens.. I am hoping the person who wrote this article will continue and show how this is done.
tienen el diagrama?
cesarbarrionuevo9 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 35
Tutti i Tempi: 7,743
