Introduzione
The hard disk drive is the data storage device for your computer. If it breaks, you may choose to replace it with either another 2.5" SATA hard drive or an SSD. An SSD does not have any moving parts, is more resistant to shock, has faster read and write speeds, and runs quieter than a hard disk drive. However, SSDs are also more expensive.
Parti
Nessuna parte richiesta.
Unscrew the six screws on the back panel of the laptop using a PH1 Phillips bit.
  • Unscrew the six screws on the back panel of the laptop using a PH1 Phillips bit.
  • These screws are attached to the panel. When unscrewing, be sure to stop when you here a click.
Aggiungi Commento
Lift the back panel from the side closest to the battery and remove the panel.
  • Lift the back panel from the side closest to the battery and remove the panel.
Aggiungi Commento
Slide the hard drive to the right, away from the RAM modules. Lift the hard drive from the side closest to the RAM modules.
  • Slide the hard drive to the right, away from the RAM modules.
  • Lift the hard drive from the side closest to the RAM modules.
  • When re-inserting the hard drive, ensure that the copper contacts on the drive's connector are facing upwards.
Aggiungi Commento
Conclusione
James Morizzo
Membro da: 29/09/2014
439 Reputazione
3 Guide realizzate
USF Tampa, Team 1-4, Hickman Fall 2014 Membro di USF Tampa, Team 1-4, Hickman Fall 2014
USFT-HICKMAN-F14S1G4
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,043
