Salta al contenuto principale
Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement
Cosa ti serve
  1. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Back Panel: passo 1, immagine 1 di 2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Back Panel: passo 1, immagine 2 di 2
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: passo 2, immagine 1 di 1
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Wi-Fi Card: passo 3, immagine 1 di 2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Wi-Fi Card: passo 3, immagine 2 di 2
    • Pull up the black foam adhesive that covers the screw and connectors holding the Wi-Fi card in place.
  4. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: passo 4, immagine 1 di 2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: passo 4, immagine 2 di 2
    • Using an opening tool, lift up on the black and white coaxial cables on the Wi-Fi card and gently pull upward to unplug them.
    • When reconnecting the cables, be sure to match the colors to the arrows on the Wi-Fi card.
  5. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: passo 5, immagine 1 di 2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: passo 5, immagine 2 di 2
    • Remove the single 3 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
    • Gently lift the Wi-Fi card out of the computer.
Conclusione
Kristen Gismondi
Membro da: 11/12/14
82.723 Reputazione
202 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.442 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 58
Tutti i Tempi: 1,073
