Salta al contenuto principale
Lenovo IdeaPad N586 Fan Replacement
Cosa ti serve
  1. Lenovo IdeaPad N586 Fan Replacement, Battery: passo 1, immagine 1 di 2 Lenovo IdeaPad N586 Fan Replacement, Battery: passo 1, immagine 2 di 2
    • To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
  2. Lenovo IdeaPad N586 Fan Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad N586 Fan Replacement: passo 2, immagine 2 di 2
    • Now push the right clip to the right and hold it while using your other hand to pull the battery out.
  3. Lenovo IdeaPad N586 Fan Replacement, Hard Drive: passo 3, immagine 1 di 1
    • Now remove the last two screws highlighted
  4. Lenovo IdeaPad N586 Fan Replacement: passo 4, immagine 1 di 2 Lenovo IdeaPad N586 Fan Replacement: passo 4, immagine 2 di 2
    • Push hard drive away from the center of the chassis.
    • Lift the hard drive out of the chassis using the tab located on the drive.
  5. Lenovo IdeaPad N586 Fan Replacement, Memory: passo 5, immagine 1 di 2 Lenovo IdeaPad N586 Fan Replacement, Memory: passo 5, immagine 2 di 2
    • Now push the little clips out away from the memory to unlock the memory.
  6. Lenovo IdeaPad N586 Fan Replacement: passo 6, immagine 1 di 1
    • After unlocking the memory from it's position, pull the memory out.
  7. Lenovo IdeaPad N586 Fan Replacement, Keyboard: passo 7, immagine 1 di 1
    • Remove three screws on bottom of case. They have a little keyboard image next to them. If you don't do this first, the keyboard will not come off. Place the plastic spudger right under the edge of the keyboard and lift up the keyboard.
  8. Lenovo IdeaPad N586 Fan Replacement: passo 8, immagine 1 di 1
    • Slowly and gently lift the keyboard up to separate from the chassis.
  9. Lenovo IdeaPad N586 Fan Replacement: passo 9, immagine 1 di 1
    • Gently lift the keyboard off the chassis.
    • Carefully disconnect the keyboard from the laptop by unhooking the keyboard ribbon.
  10. Lenovo IdeaPad N586 Fan Replacement: passo 10, immagine 1 di 1
    • Now remove the keyboard from the computer.
  11. Lenovo IdeaPad N586 Fan Replacement, Fan: passo 11, immagine 1 di 2 Lenovo IdeaPad N586 Fan Replacement, Fan: passo 11, immagine 2 di 2
    • Pull the plug shown.
  12. Lenovo IdeaPad N586 Fan Replacement: passo 12, immagine 1 di 2 Lenovo IdeaPad N586 Fan Replacement: passo 12, immagine 2 di 2
    • Lift up fan.
    • Remove two highlighted screws.
  13. Lenovo IdeaPad N586 Fan Replacement: passo 13, immagine 1 di 1
    • This is the fan separated from the motherboard.
Conclusione
Patrick
Membro da: 04/08/14
453 Reputazione
3 Guide realizzate
Cal Poly, Team 8-7, Regan Spring 2014 Membro di Cal Poly, Team 8-7, Regan Spring 2014
CPSU-REGAN-S14S8G7
5 Membri
10 Guide realizzate
Un commento
These instructions are incomplete. There are no steps to getting from removing the keyboard to getting to the fan. There may be more missing.
Clint Hatchett - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,017
