Salta al contenuto principale
Lenovo IdeaPad Flex 4-1470 Motherboard Replacement
Cosa ti serve
  1. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Lower Case: passo 1, immagine 1 di 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: passo 2, immagine 2 di 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Cooling Fan: passo 3, immagine 1 di 2 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Cooling Fan: passo 3, immagine 2 di 2
    • Remove the two 4 mm Phillips #0 screws which mount the fan.
  4. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: passo 4, immagine 1 di 3 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: passo 4, immagine 2 di 3 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using the Precision Tweezers, remove the 2 gray wires around the fan from their clips.
  5. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: passo 5, immagine 1 di 2 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: passo 5, immagine 2 di 2
    • Use 2 plastic opening tools to remove the fans power wire from the Mother board and remove the fan.
    • Lift the cooling fan out of the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Wifi Card: passo 6, immagine 1 di 1
    • Remove the foam on the WIFI card.
  7. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the wires attached to the WIFI card.
  8. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: passo 8, immagine 1 di 1
    • Unscrew the 4mm screw holding wifi card.
  9. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Motherboard: passo 9, immagine 1 di 1
    • Unscrew the twelve 4mm screws with a #0 Phillips screwdriver.
  10. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: passo 10, immagine 1 di 1
    • Remove the motherboard.
    • The motherboard will be in place when the screw holes line up.
Conclusione
Altre 2 persone hanno completato questa guida.
Elijah Ellis
Membro da: 11/08/18
616 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,294
