Salta al contenuto principale
Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement
Cosa ti serve
  1. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Lower Case: passo 1, immagine 1 di 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: passo 2, immagine 2 di 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Cooling Fan: passo 3, immagine 1 di 2 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Cooling Fan: passo 3, immagine 2 di 2
    • Remove the two 4 mm Phillips #0 screws which mount the fan.
  4. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: passo 4, immagine 1 di 3 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: passo 4, immagine 2 di 3 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using the Precision Tweezers, remove the 2 gray wires around the fan from their clips.
  5. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: passo 5, immagine 1 di 2 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: passo 5, immagine 2 di 2
    • Use 2 plastic opening tools to remove the fans power wire from the Mother board and remove the fan.
    • Lift the cooling fan out of the laptop.
Conclusione
USF Tampa, Team S1-G6, Thompson Fall 2017 Membro di USF Tampa, Team S1-G6, Thompson Fall 2017
USFT-THOMPSON-F17S1G6
3 Membri
10 Guide realizzate
Un commento
will the same fan fit to lenovo ideapad flex 5 1470 ?
Rajeshwar Choudhary - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,626
