Salta al contenuto principale
Lenovo IdeaPad 730S 13IML/IWL Battery replacement
Cosa ti serve
  1. Lenovo IdeaPad 730S 13IML/IWL Battery replacement, Remove the back cover: passo 1, immagine 1 di 2 Lenovo IdeaPad 730S 13IML/IWL Battery replacement, Remove the back cover: passo 1, immagine 2 di 2
    • Start by taking out your Torx T4/5 bit from your iFixit-kit to do this. It's unfortunate companies like Lenovo have to use these kinds of screws.
    • Unscrew the 9 Torx and T5 screws from the bottom.
  2. Lenovo IdeaPad 730S 13IML/IWL Battery replacement, Removing the battery: passo 2, immagine 1 di 3 Lenovo IdeaPad 730S 13IML/IWL Battery replacement, Removing the battery: passo 2, immagine 2 di 3 Lenovo IdeaPad 730S 13IML/IWL Battery replacement, Removing the battery: passo 2, immagine 3 di 3
    • Pry the back cover open with an opening tool.
    • After you have the back cover off, you have access to the battery and all the other components.
    • Use a Phillips 00 bit to unscrew the 2 screws holding in the battery. Then remove the connector gently.
  3. Lenovo IdeaPad 730S 13IML/IWL Battery replacement, Removing the battery - Continued: passo 3, immagine 1 di 2 Lenovo IdeaPad 730S 13IML/IWL Battery replacement, Removing the battery - Continued: passo 3, immagine 2 di 2
    • Un-route the speaker wire, as when it comes to pulling out the battery, the speakers will get caught/possibly break if this isn't done.
    • Check that no other wires are tangled on the battery.
    • After doing so, gently pry out the battery until it comes free.
    • It may be wise to re-apply the thermal paste on the cpu, as it'll help it's thermal performance. To do this, loosen the 4 screws around the cpu, and 2 around the fan with a Phillips 00 bit.
Conclusione
To reassemble your device, follow these instructions in reverse order. Happy computing!
Altre 2 persone hanno completato questa guida.
Nick P
Membro da: 01/17/22
1.672 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 80
Tutti i Tempi: 2,623
