Salta al contenuto principale
Lenovo IdeaPad 5 15ITL05 Battery Replacement
Cosa ti serve
  1. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Unfasten the back cover: passo 1, immagine 1 di 2 Lenovo IdeaPad 5 15ITL05 Battery Replacement, Unfasten the back cover: passo 1, immagine 2 di 2
    • Use a T5 Torx driver to remove nine screws securing the back cover.
    • The three screws on the hinge side will be longer.
  2. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 2 Loosen the back cover: passo 2, immagine 1 di 3 Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 2 Loosen the back cover: passo 2, immagine 2 di 3 Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 2 Loosen the back cover: passo 2, immagine 3 di 3
    • The back cover is held on by plastic tabs around the entire perimeter of the cover.
    • Use plastic pry tools at the seam. I like to start near the hinge.
  3. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 3 Remove the back cover: passo 3, immagine 1 di 2 Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 3 Remove the back cover: passo 3, immagine 2 di 2
    • Once all the tabs are loose, you will be able to remove the cover.
  4. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Disconnect the battery: passo 4, immagine 1 di 2 Lenovo IdeaPad 5 15ITL05 Battery Replacement, Disconnect the battery: passo 4, immagine 2 di 2
    • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
  5. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Unfasten the battery: passo 5, immagine 1 di 1
    • Use a Phillips screwdriver to remove the four screws securing the battery.
    • Note: Two of the screws on the left in the image will also hold in the SATA drive bracket.
  6. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 6 Remove the battery: passo 6, immagine 1 di 1
    • Remove the battery.
Conclusione
E N
Membro da: 11/21/22
422 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 78
Tutti i Tempi: 409
