Salta al contenuto principale
Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement
Cosa ti serve
  1. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement, USB/SD Ports: passo 1, immagine 1 di 1
    • Begin by placing your laptop upside down so that you can see the labels on the back.
  2. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: passo 2, immagine 1 di 1
    • Remove the 10 silver screws from the bottom of the laptop.
    • Keep these screws in a safe place like a magnetic board to keep them from getting lost.
    • (Silver, 5.8mm Phillips #0)
  3. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: passo 3, immagine 1 di 1
    • Carefully remove the back panel from the laptop.
    • Proceed slowly and use wedges to avoid damaging the panel.
  4. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: passo 4, immagine 1 di 1
    • Locate the USB/SD Ports in the top left corner of the laptop.
  5. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: passo 5, immagine 1 di 1
    • Remove the two black screws holding the USB/SD port in place.
    • (Black, 3.35mm Phillips #0)
  6. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: passo 6, immagine 1 di 1
    • Gently disconnect the black and red wires from the board.
    • Be sure not to pull too hard on the wires.
  7. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: passo 7, immagine 1 di 1
    • Remove the blue cable from the board.
  8. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: passo 8, immagine 1 di 1
    • Remove your old USB/SD ports
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 14
Tutti i Tempi: 86
