Salta al contenuto principale
Lenovo IdeaPad 3-15IIL05 Back Cover Replacement
Cosa ti serve
  1. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Unfasten the back cover: passo 1, immagine 1 di 2 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Unfasten the back cover: passo 1, immagine 2 di 2
    • Use a Phillips screwdriver to remove the ten screws securing the back cover:
    • Six 7.6 mm-long screws
    • Four 4.7 mm-long screws
  2. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Insert an opening pick: passo 2, immagine 1 di 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Insert an opening pick: passo 2, immagine 2 di 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Insert an opening pick: passo 2, immagine 3 di 3
    • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release.
    • Insert the flat side of an opening pick between the top left corner of the back cover and frame.
    • Angle the pick down to about 45 degrees.
  3. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the left clips: passo 3, immagine 1 di 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the left clips: passo 3, immagine 2 di 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the left clips: passo 3, immagine 3 di 3
    • Keep the opening pick angled down at about 45 degrees while sliding it along the front and side edges to help release the clips.
    • Slide the pick to the bottom left corner of the laptop to release the left clips.
  4. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the bottom clips: passo 4, immagine 1 di 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the bottom clips: passo 4, immagine 2 di 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the bottom clips: passo 4, immagine 3 di 3
    • Slide the opening pick to the bottom right corner to release the bottom clips.
  5. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the right clips: passo 5, immagine 1 di 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the right clips: passo 5, immagine 2 di 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the right clips: passo 5, immagine 3 di 3
    • Slide the opening pick to the top right corner to release the right clips.
  6. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Insert an opening pick: passo 6, immagine 1 di 2 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Insert an opening pick: passo 6, immagine 2 di 2
    • Insert the flat end of an opening pick between the back cover and frame, to the left of the right hinge.
    • Pry the back cover up with the pick to release the top right clips.
    • Leave the pick inserted next to the right hinge.
  7. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the top clips: passo 7, immagine 1 di 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the top clips: passo 7, immagine 2 di 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Release the top clips: passo 7, immagine 3 di 3
    • Angle the pick up to about 45 degrees.
    • Slide the opening pick to the top left corner to release the remaining clips.
  8. Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Remove the back cover: passo 8, immagine 1 di 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Remove the back cover: passo 8, immagine 2 di 3 Lenovo IdeaPad 3-15IIL05 Back Cover Replacement, Remove the back cover: passo 8, immagine 3 di 3
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press firmly around the perimeter to engage all the clips.
Conclusione
Spencer Day
Membro da: 09/14/22
55.203 Reputazione
408 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.432 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 73
Ultimi 30 Giorni: 295
Tutti i Tempi: 1,401
