Salta al contenuto principale
Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement
Cosa ti serve
  1. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement, Lower Case: passo 1, immagine 1 di 1
    • First, before you do anything, make sure the computer has been turned off and unplugged.
    • Place the the computer bottom facing up. Unscrew the eleven 6 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 2, immagine 2 di 2
    • Use an opening tool to gently disconnect the clips on the side of the back panel.
    • DO NOT try to force open the panel, as this may cause damage to it.
  3. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 3, immagine 1 di 2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 3, immagine 2 di 2
    • Pry out the optical drive opposite of the laptop.
    • Since the screws have already been removed, you will not need to worry about any more screws on the optical drive.
  4. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 4, immagine 1 di 3 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 4, immagine 2 di 3 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 4, immagine 3 di 3
    • Release the remaining clasp and remove the lower case.
  5. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement, Hard Disk Drive (HDD): passo 5, immagine 1 di 1
    • Use a Phillips #1 screwdriver to unscrew the four 5 mm screws that are holding the hard drive in place.
  6. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 6, immagine 1 di 2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 6, immagine 2 di 2
    • Do not lift the hard drive straight up; this might break the connection port.
    • Softly slide the hard drive away from the port.
  7. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 7, immagine 1 di 2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 7, immagine 2 di 2
    • Use a Phillips #1 screwdriver remove the 2 screws from both sides of the hard drive (total of 4 screws).
  8. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: passo 8, immagine 1 di 1
    • Remove the hard drive from the housing mount.
Conclusione
Gateway, Team 1-3, Pee Fall 2023 Membro di Gateway, Team 1-3, Pee Fall 2023
GCC-PEE-F23S1G3
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 119
