Salta al contenuto principale
Lenovo IdeaPad 110-17IKB Fan Replacement
Cosa ti serve
  1. Lenovo IdeaPad 110-17IKB Fan Replacement, Lower Case: passo 1, immagine 1 di 1
    • First, before you do anything, make sure the computer has been turned off and unplugged.
    • Place the the computer bottom facing up. Unscrew the eleven 6 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad 110-17IKB Fan Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad 110-17IKB Fan Replacement: passo 2, immagine 2 di 2
    • Use an opening tool to gently disconnect the clips on the side of the back panel.
    • DO NOT try to force open the panel, as this may cause damage to it.
  3. Lenovo IdeaPad 110-17IKB Fan Replacement: passo 3, immagine 1 di 2 Lenovo IdeaPad 110-17IKB Fan Replacement: passo 3, immagine 2 di 2
    • Pry out the optical drive opposite of the laptop.
    • Since the screws have already been removed, you will not need to worry about any more screws on the optical drive.
  4. Lenovo IdeaPad 110-17IKB Fan Replacement: passo 4, immagine 1 di 3 Lenovo IdeaPad 110-17IKB Fan Replacement: passo 4, immagine 2 di 3 Lenovo IdeaPad 110-17IKB Fan Replacement: passo 4, immagine 3 di 3
    • Release the remaining clasp and remove the lower case.
  5. Lenovo IdeaPad 110-17IKB Fan Replacement, Fan: passo 5, immagine 1 di 2 Lenovo IdeaPad 110-17IKB Fan Replacement, Fan: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Unscrew the four 6 mm Phillips #0 screws that secure the fan.
    • Push the white fan connector directly out of its port using tweezers or a pry tool.
    • Lift the fan up and out of the chassis.
Conclusione
Gateway, Team 1-3, Pee Fall 2023 Membro di Gateway, Team 1-3, Pee Fall 2023
GCC-PEE-F23S1G3
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 14
Tutti i Tempi: 54
