Salta al contenuto principale
Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement
Cosa ti serve
  1. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement, Back Case: passo 1, immagine 1 di 1
    • Remove the thirteen 6 mm Phillips #0 screws.
  2. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: passo 2, immagine 2 di 2
    • Use an opening tool to gently disconnect most of the clips on the back panel.
    • DO NOT force the panel out towards the optical disk drive.
  3. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: passo 3, immagine 1 di 3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: passo 3, immagine 2 di 3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: passo 3, immagine 3 di 3
    • Pry the disk drive away from the center of the laptop.
    • Don't worry about any screws since we already removed the screws that are associated with the drive.
    • Once the drive is removed, remove the one 2 mm Phillips #0 screw that is now exposed.
  4. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: passo 4, immagine 1 di 3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: passo 4, immagine 2 di 3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: passo 4, immagine 3 di 3
    • Unclip any of the remaining clips and remove the back panel.
  5. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement, Battery Replacement: passo 5, immagine 1 di 1
    • Remove the four 6 mm Phillips #0 mounting screws.
  6. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: passo 6, immagine 1 di 3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: passo 6, immagine 2 di 3 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: passo 6, immagine 3 di 3
    • Detach the wire connected to the motherboard and remove the battery assembly.
  7. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement, Hard Disk Drive Replacement: passo 7, immagine 1 di 1
    • Remove the four 4 mm Phillips #0 mounting screws attaching the caddy to the frame.
  8. Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: passo 8, immagine 1 di 2 Lenovo IdeaPad 110 Touch-15ACL Hard Disk Drive Replacement: passo 8, immagine 2 di 2
    • Gently remove the caddy away from the motherboard.
    • If you are removing an already existing HDD, unplug the component along with the caddy and remove the four screws mounting the caddy to the HDD.
Conclusione
Clemson, Team 2-3, Hunter Spring 2022 Membro di Clemson, Team 2-3, Hunter Spring 2022
CLEM-HUNTER-S22S2G3
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 27
Tutti i Tempi: 385
