Parti
Nessuna parte richiesta.
Lay the computer down on its side as shown.
  • Lay the computer down on its side as shown.
  • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
Aggiungi Commento
Gently slide the side panel straight back and remove from the computer.
  • Gently slide the side panel straight back and remove from the computer.
Aggiungi Commento
With your hands remove the 14mm screw that holds the cover on the back panel.
  • With your hands remove the 14mm screw that holds the cover on the back panel.
  • Gently pull the flap back to expose the T.V. Tuner screw.
Aggiungi Commento
Use the Phillips #2 to remove the 8mm screw that holds the T.V. Tuner in place.
  • Use the Phillips #2 to remove the 8mm screw that holds the T.V. Tuner in place.
Aggiungi Commento
With moderate force, pull straight up on the chip to remove it from the computer.
  • With moderate force, pull straight up on the chip to remove it from the computer.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Timothy Grebe
Membro da: 19/10/2014
1.304 Reputazione
9 Guide realizzate
Cal Poly, Team 10-39, Amido Fall 2014 Membro di Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 408
