Salta al contenuto principale
Lenovo IdeaCentre K410 RAM Module Replacement
Cosa ti serve
  1. Lenovo IdeaCentre K410 RAM Module Replacement, Side Panel: passo 1, immagine 1 di 1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 RAM Module Replacement: passo 2, immagine 1 di 1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 RAM Module Replacement, RAM Module: passo 3, immagine 1 di 1
    • Push down on the white clips on both sides of the memory module to release it.
    • Gently pull up on the memory module to remove it from the unit.
Conclusione
When inserting the memory module, make sure that the notch on it aligns correctly with the key on the memory connector. Push the module straight down into the connector until the retaining clips close.
Altre 2 persone hanno completato questa guida.
Timothy Grebe
Membro da: 10/19/14
1.634 Reputazione
9 Guide realizzate
Cal Poly, Team 10-39, Amido Fall 2014 Membro di Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
4 Membri
18 Guide realizzate
2 Commenti
sounds very hard to replace a ram “sarcastically“
you probley can replace a ram if you know what ram is so
remliv - Replica
But it is still good to have guides on everything
im glad that ifixit exists
remliv - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,438
