Salta al contenuto principale
Lenovo IdeaCentre K410 Power Supply Unit Replacement
Cosa ti serve
  1. Lenovo IdeaCentre K410 Power Supply Unit Replacement, Side Panel: passo 1, immagine 1 di 1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 Power Supply Unit Replacement: passo 2, immagine 1 di 1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 Power Supply Unit Replacement, Power Supply Unit: passo 3, immagine 1 di 2 Lenovo IdeaCentre K410 Power Supply Unit Replacement, Power Supply Unit: passo 3, immagine 2 di 2
    • Unplug both sets of wires attaching the power supply unit to the motherboard.
    • The largest connection requires a significant amount of force to be removed.
  4. Lenovo IdeaCentre K410 Power Supply Unit Replacement: passo 4, immagine 1 di 3 Lenovo IdeaCentre K410 Power Supply Unit Replacement: passo 4, immagine 2 di 3 Lenovo IdeaCentre K410 Power Supply Unit Replacement: passo 4, immagine 3 di 3
    • Unplug all cords attached to the optical drive and hard drive.
  5. Lenovo IdeaCentre K410 Power Supply Unit Replacement: passo 5, immagine 1 di 1
    • Using the Phillips #2 driver, unscrew the four 8mm screws attaching the power supply unit to the outside of the computer.
  6. Lenovo IdeaCentre K410 Power Supply Unit Replacement: passo 6, immagine 1 di 1
    • Remove the power supply unit by pulling away from the screw side and then out.
Conclusione
Altre 9 persone hanno completato questa guida.
Timothy Grebe
Membro da: 10/19/14
1.619 Reputazione
9 Guide realizzate
Cal Poly, Team 10-39, Amido Fall 2014 Membro di Cal Poly, Team 10-39, Amido Fall 2014
CPSU-AMIDO-F14S10G39
4 Membri
18 Guide realizzate
Un commento
What part do I need to replace the POWER BUTTON, it's broke and have to press inside to power on?
Tracy Estes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 33
Tutti i Tempi: 4,277
