Salta al contenuto principale
Lenovo Flex 6-11IGM Display Replacement
Cosa ti serve
  1. Lenovo Flex 6-11IGM Display Replacement, Display: passo 1, immagine 1 di 2 Lenovo Flex 6-11IGM Display Replacement, Display: passo 1, immagine 2 di 2
    • Place the laptop face-up.
    • Open the laptop.
  2. Lenovo Flex 6-11IGM Display Replacement: passo 2, immagine 1 di 1
    • Using a plastic opening pick, begin to gently separate the display from the case, moving around the edge.
    • Using the plastic opening pick, begin to gently separate the plastic trim from the case, moving around the edge.
  3. Lenovo Flex 6-11IGM Display Replacement: passo 3, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the three 2.5 mm screws that secure the display.
    • Secure a suction cup to the screen and pull it free from the upper case with light force.
    • Rest the display on the keyboard.
  4. Lenovo Flex 6-11IGM Display Replacement: passo 4, immagine 1 di 2 Lenovo Flex 6-11IGM Display Replacement: passo 4, immagine 2 di 2
    • Disengage the cable located at the bottom of the display.
    • Slide a plastic opening pick under the brown bar, lifting the bar up, and disengage the wire with your fingers.
    • Disengage the cable at the bottom left of the display with your fingers.
    • Disengage the cable at the top center of the display using your fingers and remove the cable from the display housing.
  5. Lenovo Flex 6-11IGM Display Replacement: passo 5, immagine 1 di 1
    • Remove the display.
Conclusione
Un commento
Can you replace the digitizer separately? Or do you have to get the digitizer and lcd combo for replacement? Is it worth it at $130 for the replacement? Laptop is only a couple years old…
Tyson Strickland - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 615
