Introduzione
RAM should be replaced if the computer has memory issues. This is sometimes the case when the computer won't boot, or simply runs too slow for comfort.
Parti
Turn off the computer.
  • Turn off the computer.
  • Disconnect the charging cable from the computer.
  • Failure to unplug the cable could result in electric shock.
  • Flip the computer upside down.
Aggiungi Commento
Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position. Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
Aggiungi Commento
Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
  • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
Aggiungi Commento
Remove the seven 5.3 mm Phillips  #1 screws holding the back panel in place.
  • Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
Aggiungi Commento
Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly. If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
  • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
  • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
Aggiungi Commento
The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
  • The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
Aggiungi Commento
Locate the RAM Sticks in the computer. They should be in the corner of the laptop. Locate the RAM Sticks in the computer. They should be in the corner of the laptop.
  • Locate the RAM Sticks in the computer. They should be in the corner of the laptop.
Aggiungi Commento
Using a spudger, push one of the metal rods on either side of the RAM stick away from it until you hear a light clicking noise. Repeat this procedure on the other metal rod on the opposite side of the RAM stick. If you push both metal rods away from the RAM stick as directed, the RAM stick will pop up at an angle.
  • Using a spudger, push one of the metal rods on either side of the RAM stick away from it until you hear a light clicking noise. Repeat this procedure on the other metal rod on the opposite side of the RAM stick.
  • If you push both metal rods away from the RAM stick as directed, the RAM stick will pop up at an angle.
Aggiungi Commento
Gently pull out the stick of RAM.
  • Gently pull out the stick of RAM.
  • If you wish to remove the second stick of RAM, do so by following steps two and three again.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Dennis Wong
Membro da: 11/01/2013
468 Reputazione
5 Guide realizzate
Cal Poly, Team 18-40, Regan Winter 2013 Membro di Cal Poly, Team 18-40, Regan Winter 2013
CPSU-REGAN-W13S18G40
5 Membri
7 Guide realizzate
maine apne lenovo g560 laptop me crucial 4gb ram add kiya lekin mera system format nahi ho raha h. mujhe kya karna chahiye mujhe email kare. vikasmaddeshiya056@gmail.com
vikkivikas056 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 35
Tutti i Tempi: 9,377
