Introduzione
Follow this guide to remove the optical drive from the computer.
Parti
Nessuna parte richiesta.
Turn off the computer.
  • Turn off the computer.
  • Disconnect the charging cable from the computer.
  • Failure to unplug the cable could result in electric shock.
  • Flip the computer upside down.
Aggiungi Commento
Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position. Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
Aggiungi Commento
Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
  • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
Aggiungi Commento
Remove the seven 5.3 mm Phillips  #1 screws holding the back panel in place.
  • Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
Aggiungi Commento
Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly. If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
  • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
  • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
Aggiungi Commento
The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
  • The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
Aggiungi Commento
Locate the Optical Drive 4.7 mm Philips #1 screw, which secures the Optical Drive into the body of the laptop. Locate the Optical Drive 4.7 mm Philips #1 screw, which secures the Optical Drive into the body of the laptop.
  • Locate the Optical Drive 4.7 mm Philips #1 screw, which secures the Optical Drive into the body of the laptop.
Aggiungi Commento
Using the Philips #1 Screwdriver, remove the Optical Drive 4.7 mm Philips #1 screw.  Once you remove the screw, locate the metal tab beneath the screw and push it outwards.
  • Using the Philips #1 Screwdriver, remove the Optical Drive 4.7 mm Philips #1 screw. Once you remove the screw, locate the metal tab beneath the screw and push it outwards.
  • It may be useful to use the spudger to push the metal tab, as there is not enough space for your finger or plastic opening tool.
  • Be firm, yet gentle to avoid damaging the electronic connections.
Aggiungi Commento
Slide the Optical Drive smoothly out of its slot. Slide the Optical Drive smoothly out of its slot.
  • Slide the Optical Drive smoothly out of its slot.
Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
Dennis Wong
Membro da: 11/01/2013
468 Reputazione
5 Guide realizzate
Cal Poly, Team 18-40, Regan Winter 2013 Membro di Cal Poly, Team 18-40, Regan Winter 2013
CPSU-REGAN-W13S18G40
5 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 38
Tutti i Tempi: 3,843
