Salta al contenuto principale
Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement
Cosa ti serve
Panoramica Video
  1. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Switch off the laptop, disconnect the AC adapter, and remove the battery.
  2. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory / HDD cover: passo 2, immagine 1 di 2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory / HDD cover: passo 2, immagine 2 di 2
    • Remove the screws securing the Memory / HDD cover.
    • Slide the cover down and remove it.
  3. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory Modules: passo 3, immagine 1 di 2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory Modules: passo 3, immagine 2 di 2
    • To pop up the memory module you’ll have to spread latches on both sides of the slot.
    • MEMORY
    • Speed 1600 MHz / PC3L-12800
    • Technology DDR3L SDRAM SODIMM
    • Max Supported Size 16 GB
    • Form Factor SO-DIMM 204-pin
    • Slots Qty 2
    • Empty Slots 1
  4. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): passo 4, immagine 1 di 3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): passo 4, immagine 2 di 3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): passo 4, immagine 3 di 3
    • Remove two screws securing the hard drive mounting bracked.
    • Slide the HDD to the left to disconnect it from the motherboard and remove it from the device.
    • Remove two screws on each side of the HDD to remove the mounting bracket.
    • Now you have to transfer the mounting bracket to the new HDD or SSD.
  5. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Wireless / Bluetooth Card: passo 5, immagine 1 di 2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Wireless / Bluetooth Card: passo 5, immagine 2 di 2
    • Remove the screw and disconnect the two coaxial antenna cables from the WiFi card.
    • Pop it up and remove it from the slot.
    • Wireless N M.2, or Next Generation Form Factor (NGFF) Card.
  6. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: passo 6, immagine 1 di 3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: passo 6, immagine 2 di 3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: passo 6, immagine 3 di 3
    • Complementary Metal-Oxide-Semiconductor (CMOS) aka Real-Time Clock (RTC)
    • CR2032
  7. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement: passo 7, immagine 1 di 1
    • That's all.
Conclusione
Altre 3 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.534 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.489 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 75
Tutti i Tempi: 7,315
