Introduzione
You can easily replace this laptop battery to get back on the amazing battery life it has!
Cosa ti serve
Unplug and turn off the chromebook device.
Remove the SD card if you are using one.
Turn the laptop over.
Remove the 10 phillips head screws and keep them organized.
Using a Spudger, carefully separate the cover from the corner. It snaps back in, so make sure to not break any clips.
Take out the cover and set it aside.
To disconnect the battery, carefully pull the black connector in a parallel direction to the laptop.
Lift the clip on the motherboard connector.
Take out the ribbon cable in an up and out direction from the motherboard connector.
Gently peel it off, it has some mild glue to attach it to the battery.
Remove the four Phillips head screws attaching the Battery.
Lift the battery from the casing.
To reassemble your device, follow these instructions in reverse order. You must plug it back to the wall power to turn it back on!
Congrats! You've upgraded your laptop battery!
