Introduzione
USe this guide to replace the tripod socket.
Parti
Nessuna parte richiesta.
Carefully unscrew the four (4) screws on the bottom of the camera. Make sure you don't miss the one that's actually in the tripod socket hole.
  • Carefully unscrew the four (4) screws on the bottom of the camera.
  • Make sure you don't miss the one that's actually in the tripod socket hole.
Aggiungi Commento
Open the back door on the camera by pushing down on the door latch.
  • Open the back door on the camera by pushing down on the door latch.
Aggiungi Commento
Apply pressure to the bottom plate and it will pop off.
  • Apply pressure to the bottom plate and it will pop off.
  • From here, you can replace the bottom plate, or continue on to further steps.
Aggiungi Commento
Conclusione
Zachary
Membro da: 12/04/2011
31 Reputazione
2 Guide realizzate
Cal Poly, Team 18-19, Garner Spring 2011 Membro di Cal Poly, Team 18-19, Garner Spring 2011
CPSU-GARNER-S11S18G19
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,095
